Woody1515
- Apr 13, 2017
- 72
Hello!
Let’s say you are pouring a 24’X24’ slab on grade for a detached garage. You have the typical edge thickening under the exterior walls, vapour barrier and compacted gravel under the slab, etc. Is it still common practice to create control joints in the slab? If so, what would the layout of the joints looks like? Something like an X that intersects the slab into 4 12’X12’ sections? I cannot ever remember seeing control joints in a detached garage slab...
Thanks in advance!
Thanks in advance!
