TroyD
- Jan 28, 2011
- 98
I could use some advice on a small remodel project I'm working on. Typical main street brick building circa 1900 in small town Minnesota. Single story, 24' wide. 12' clear height. 2x12 roof joists and 2x12 ceiling joists pocketed into the brick wall. Limestone foundation to frost depth. Contractor encountered some deteriorated/weathered brick along the foundation at one corner of the building, likely due to poor roof drainage and poor site grading back by the alley. Contractor is proposing to remove a portion (approx. 10 LF) of the existing brick side wall and replace with CMU block, or possibly 2x6 stud wall. I assume the CMU would require a sort of leveling pad to sit on. Would need to tie into the exist brick with ties or angles equally spaced up the length of the wall for lateral stability. CMU is typically reinforced with dowels in grouted cores lapped with foundation rebar, but that doesn't work here. No change in roof loading. What are acceptable methods for replacing existing brick like this? I'm meeting the contractor and mason on site tomorrow to discuss further. I have attached a sketch.
Any advice is appreciated.
