thinksabunch
The problem is determining what size electric motor to use in a mixing application. The mixer is a battery-start, hydraulic drive, paddle-type stucco/cement mixer with a 17HP gasoline engine installed on it now. The 17HP gas engine is overkill because rather than mixing gravel, cement, sand, water - we are using the mixer to mix a powder with paper pulp. We also wanted to go with something environmentally conscious. Instead of running gasoline, we want to use electricity. We're leaning toward a DC electric motor with a smart motor control box so we can run the mixer in both directions - which it is already set up for now through the hydraulics. We know our application will require significantly less than 17HP, but were wondering how we go about figuring more precisely how many HP it will take to turn the paddle blade 50-60 turns per minute. We can control RPM with the motor control box, but we need the Goldilocks horsepower to have enough torque but not be over-powered. We have access to the end of the shaft that turns the blade on one end - so we could fab a lever or moment arm, but how to proceed? What other information is needed? Any ideas?
