Struct2468
I'm a little confused on when development length applies. I understand development length is used to transfer the tension and compression for the rebar in a beam to a column joint. Can tension development length be used to transfer uplift tension from a concrete wall to the footing? Or is this a calculation I need to check? Also, how is the shear (in the X direction of the drawing,from wind load) transferred from the wall to the footing? See the attachment. Thanks.
