I'm working on a battery charger module. It will include within it, qty 2 of MeanWell DBU-3200, connected in parallel at the AC input and DC output, powered by 220VAC.
The spec sheet says AC current typical 17A, inrush current typical 55A.
Does anyone have advice on what I should do for a protection scheme? Fusing? Breakers? They each have an internal fuse, but I can't tell what value. If I use a 50A breaker to power them both, is that sufficient protection?
And since I've been pondering and researching this, it leads me to question, what is the exact purpose of circuit breakers and fusing in a product like this? Is it just to prevent fires from a short circuit? Is it to prevent damage to components? It seems that the answer to this question is critical to deciding what to use.
Looking for any thoughts/advice/resources. Thanks!
