di plants 1
steambreath
3
Why does conductivity increase when a DI plant experiences low or no flow... Help settle a bet..
DI water is actually a bit corrosive and is, relative to most things that it can absorb or dissolve, nearly a vacuum.
This means that there is a constant incursion of contaminants into the water. That's one of the reasons that the water must continually circulate; to clean up the stuff that it picks up along its travels through the piping.
TTFN
Where are you checking the conductivity at no flow condition? What you said is not a general case with low flow unless there is channeling inside the beds. Checking the pH of regeneration reject can give you a clue about this.
What IRstuff said is true. It is difficult for most people to see any type of water as a corrosive substance, but DI water can be extremely corrosive in the right environment.
I belive quark is talking about a situation that is different from the one you are experiencing. It sounds like you are hardly using the DI system, and sometimes the conductivity reading go up for, seemingly, no reason. This same thing happens in one my plants because we installed a DI system for a process that is no longer in use. The water is now only used for lab activities, so the system stays stagnant for weeks at a time. If that is the case, you may also find that the water "stinks" due to organic growth in the piping system. Running the system for a few minutes normally fixes both problems.
If you try to measure the pH of DI water, you will notice that the value returned is not the expected 7.0, but, typically down around 4.0. The reason is that the DI water dissolved CO2 from the air which forms carbonic acid. Actually, this has as much to do with the measurement itself than anything. The instrument needs something to read, and the very small amount of acid in the water is enough to give a false low pH. A stabilizer (KCl, I think?) needs to be used to measure an acurate pH in this case.
At low flows through the resin bed you will likely encounter flow maldistribution or channeling and the resin will be exhausted locally while the bulk of the bed may yet be fully regenerated.
If the bed is put in standby and it is partially exhausted, ions will migrate from the resin sites back into the bulk water until ionic equilibrium occurs. When this occurs the conductivity will increase. That is why it is best to rinse the bed prior to returning it to service after being in standby.
