is it normal for my di water ph to drop below 6 and still have good resistivity? i have a regular di water generator that uses standard cation and anion resins. after regeneration the ph is around 9 and the resistivity is around 3 meg ohms. as i run water through it the resistivity drops and so does the ph. why does the ph drop?
