Did not get any result from ABAQUS Explicit
Eng.SaTa
Aerospace
Aug 6, 2021
19
Dear All,
I did not get any result from Abaqus explicit as attached result image.
I have no clue of possible reasons!
I changed the amplitude and BCs and nothing happened.
I would appreciate any thoughts.
Attached the
Check the output files, they should contain some warnings and errors that might indicate the reason of this problem.
Did the simulation actually run?
And check the output requests. Maybe you've suppressed all output.
Thanks for your replies.
I had specified output frequency based on "evenly spaced time intervals" and set 50 as number of intervals. This setting resulted in nothing written on odb file.
I found out when I change the output frequency to "every x units of time" and set x as 50*stable time increment, results are written on .odb file.
Sounds my problem is solved, but I am wondering why such weird thing is happening!Appreciate any thoughts.
Maybe you’ve accidentally set it to 0 instead of 50. Because normally it should work and give you results. Check the generated input files.
