We are planning to install a 2MW, 4.16KV stand-by generator to feed existing MV switchgear. Are there any special requirements for the Generator Breaker? IEEE C37.013 talks about DC components of fault current up to 75% (due to high X/R ratio), but the standard indicates it applies to "all ac high-voltage generator circuit breakers rated on a symmetrical current basis that are installed between the generator and the
transformer terminals". This generator will be feeding a MV SWGR directly, not a step-up transformer this standard refers to. Any thoughts?
