MchA
- Dec 5, 2023
- 17
Hello All,
Considering the forging ASME SA-187 Gr.5 and ASME SA-336 Gr.5, I have noticed that, in ASME II Part D they are caracterized by different values on Maximum Allowable stresses, altrough I haven't found any reference about the reason why difference is shown, especially considering the fact that ASME II Part A1 gives the possibility to use, for large forgings ASME SA-366.
I have noticed the difference in the percentace of carbonium for Gr.5 and Gr.5A, that might explain the difference between the grades in SA-366 but I can't related, with same heat treatment, the difference in mechanical properties with SA-182 Gr.5, considering the fact that it is the only grade that shows a difference between these two materials.
Does anyone know why exist that difference in mechanical properties?
Thank you in advance
