Difference Between Tube & Pipe:- 2
29
Dear All,
Refer to the subject can anyone explain what is the Difference between Tube & Pipe in terms of Technical aspect.
I Have observed the following differences Primarily :-
1. Understand that Tube will be available in Circular/Square/Rectangular, where as Pipe will be available in only Circular Form.
2. For 1" Tube the OD is 25.4 mm, whereas 1" Pipe the OD will be 33.4 mm as per B36.10.
Request/Experienced Professionals please provide difference in Technical aspect.
Venkat
Think you've nailed it already.
Tube / pipe can be somewhat interchangable, but in very broad terms,
"Pipe" is available to piping codes and standards and can be virtually any size and is made either from seamless or seamed material in discrete lengths ( usually 12m or so max. It is commonly, though not always, made to ASME B36.10 dimensions, but especially in the former Soviet Union countries can come in different sizes.
"Tube" tends to be drawn as an extruded continuous material, hence limited to relatively small sizes ( max 6-8"?)and used predominantly for instrument tubing or where you need high purity or lack of contamination. It also tends to be as you say, dimensionally precise, so a 25mm NPS "tube is exactly 25mm OD. It can often be reeled and hence have a very long length available or made in discrete lengths.
But as said it's all a bit vague and interchangeable depending on usage and location and you just need to check and confirm what it is you're dealing with. Especially in the smaller sizes.
At that's my interpretation of it. Others may have a different interpretation.
Search past threads on here, this has no doubt been answered many times previously.
Google also knows a few things
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
TUBE-- is used for Heat transfer and OD is controlled
PIPE-- is used for Mass and Heat transfer
TUBE-- is what makes the bar that holds up my drapes
PIPE-- is what supports my mailbox
Either one will suffice when I need more leverage on a stubborn wheel nut
Anti-seize [wink]
The devil is in the details; she also wears prada.
While tube tends to smaller and lighter than pipe the real difference is the specs.
Both can be made in many alloys and either seamless or welded.
Tubing is usually 100%NDT'ed in process and often by two methods while pipe is a much less tightly controlled product both in terms of tolerances and testing. Tubing also usually offers many more options in terms of special testing or special surface conditions. You can also buy tubing that cold drawn to predetermined strength levels.
Some industries (food, personal care products, and pharma) use tube for mass convenience, but this is unusual.
Often mechanical (industrial ) applications will use tube over pipe because the tight tolerances alloy parts to be used as-is with minimal or no machining.
1) @ LittleInch: "so a 25mm NPS "tube is exactly 25mm OD" . NPS = Nominal PIPE size
2) Threads are for PIPES
3) Fittings are for PIPES (flanges, elbows, etc.....)
Like I said, the terms are interchangeable....
You don't often see threaded Tube...
Tube is a generic shape used to describe a long hollow section with undefined material properties.
Tube can be square. Tube can be thick-walled. Tube can be made from porous sponge.
A coffee cup is a tube with a cap on the bottom.
I view pipe as tube with specific characteristics. The two special characteristics of pipe are:
-Pipe is a tube with a continuous cylindrical section.
-Pipe holds and transports fluids, with or without pressure.
Shell and Tube Heat Exchangers use tubes with specific heat transfer properties. Sometimes pipe does the trick as a heat exchanger tube because pipe can transport the fluid, however heat exchanging is not the core purpose of pipe.
A gate or fence can be fabricated from pipe, however structural circular hollow section (not designed for transporting fluids) would be the more correct material to use.
Instrumentation tubing could be referred to as pipe.
No it isn't (IME). It's referred to as Instrument Tubing.
