Reg Varney
- Jul 17, 2020
- 2
Scenario:
A single phase Bluffton/Franklin motor, 2.25kW with start capacitor on the motor (no run capacitor) designed for 50/60Hz running:
[ul]
[li]FLA of 12.4 amps at 230v, 60Hz,[/li]
[li]FLA of ???? amps at 230v, 50Hz?[/li]
[/ul]
The same single phase scenario with no load bench test is as follows:
[ul]
[li]230v 60Hz NLA = Expected 6.0 - 8.0 amps[/li]
[li]230v 50Hz NLA = Expected ??? amps[/li]
[/ul]
Can anybody advise me what I should expect for the above missing data?
Thanks for your time
[ul]
[/ul]
[ul]
[/ul]
