deltawhy
- Jun 1, 2011
- 95
I'm wondering if anyone can point out any obvious drawbacks to having a normal source (utility) solidly grounded (3P 4W system), with an emergency system (separately derived) impedance grounded. All circuit breakers within the main and emergency distribution would be 4 pole. There would be no single phase loads on the bus.
The reason the utility source would be solidly grounded is the utility owns the transformers and will not allow for resistance grounding. This is in Ontario, Canada.
