Different results in cohesive zone modeling for the same data input
abc123ali
82
Respected ABAQUS users, I would like to request the solution to the issue regarding making the contact in cohesive zone modelling.
1. When I used the node to surface contact in the interaction by selecting node as slave and surface as master in the discretization method the output results showed very high values for the output force-displacement curve compared to the input. why? ;This is when I used contact model cohesive zone
2. When I used node to surface as discretization method but used the master and slave surfaces and not the master surface to slave node set the results comes out closer to the input data. Why?; This is when I used contact model cohesive zone
3. When I used surface to surface discretization method and select the both surface; master,slave and not the salve node with master surface the output results shows a little far values from the original. why? This is the contact model cohesive zone
4. When I model the system using cohesive zone elements rather than contact model then the results comes out are far from the input data. Actually the input peak of nominal stress is 6.2 MPa with the contact area of plates which is 61 but when the results comes the peak force is just 325 N but the input data it is 378 N. Here I used tie constraint with node to surface and surface to surface but the results are not fine.
5. Refining the mesh is not affecting the results in all the cases but the mesh shapes. The inp files are attached here
6. The variation in result occurs when the applied displacement in the load module is from 2.4 to 2.7 but the failure disp is kept constant to be 2.4. The force output peak changes from 360 to 325 with disp 2.4 to 2.7 mm respectively. why??
7. Is it possible for using the node to surface and conversely surface to node between the two interacting surfaces for better results?
kindly suggest me a solution
Are you using contact pairs or general contact ? Abaqus/Standard or Explicit ?
