Dimension reference
Santa123
80
PL
Could you give me some tips, how can I get to know if dimension (in sketch) is referenced from H or V axis.
Respect
Santa
Hi Santa123.
It seems to be able to judge by checking the typename of Constraint.GetConstraintElement (1-3) .Parent.Parent.
In my testing, if there is only one "Axis2D", it is referring to H or V.
Here is the sample code.
(Please try it in the sketch)
Code:
'vba
Option Explicit
Sub CATMain()
    Dim selMsg As String
    selMsg = "select dimension"
    Dim constraint_obj As constraint
    Dim resultMsg As String
    Do
        ' Select Constraint
        Set constraint_obj = SelectItem(selMsg, Array("Constraint"))
        If constraint_obj Is Nothing Then Exit Do
        If isReferenced_HorV(constraint_obj) Then
            resultMsg = "Yes"
        Else
            resultMsg = "No"
        End If
        MsgBox "referenced from H or V : " & resultMsg
    Loop
End Sub
Private Function isReferenced_HorV( _
    ByVal con As constraint) As Boolean
    Dim i As Long, ref As Reference
    Dim parenAxis2DCount As Long
    parenAxis2DCount = 0
    For i = 1 To 3
        On Error Resume Next
        Set ref = con.GetConstraintElement(i)
        On Error GoTo 0
        If ref Is Nothing Then GoTo continue
        If typename(ref.Parent.Parent) = "Axis2D" Then
            parenAxis2DCount = parenAxis2DCount + 1
        End If
continue:
    Next
    isReferenced_HorV = IIf(parenAxis2DCount = 1, True, False)
End Function
Private Function SelectItem( _
    ByVal msg$, _
    ByVal filter As Variant) _
    As AnyObject
    Dim sel As Variant
    Set sel = CATIA.ActiveDocument.selection
    sel.Clear
    Select Case sel.SelectElement2(filter, msg, False)
        Case "Cancel", "Undo", "Redo"
            Exit Function
    End Select
    Set SelectItem = sel.Item(1).Value
    sel.Clear
End Function
