dimension 1
dho
255
after extrude a circle, how to dimension the height? (if a rect, there is a side to pick.)
thanks.
If you want to add a Annotation dimension to the extruded length in the 3D model, select the end faces.
If that's not what you are asking, please clarify.
ok. is this the right way?
tools - dimensions --- smart --- reference dimension -- click on two surfaces.
thanks.
Or rmb on the feature and edit the value.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
