jackorsen88
im trying to make a TolAnalisys on a assembly but i am having problem to define tolerances on dimension with dimexpert.
When i create dimension i seem not have a option to set the upper and lower tolerance. The dialog window Tolerance/precision says "Basic" and .12.
I have tried the Dimexpert options Block Tolerance, General Tolerance, General Block Tolerance...
And another problem is. I have imported step in the part, but when i create the dimension on some pins only surface on one pin is taken on other pins it says "failed to create dimension for selected face of feature"..
Thank you
Thank you
