DIN 17100
martensiticz
Materials
EG
IS DIN 17100 STILL APPLICABLE?
It is not neccessary to post the same question in 3 different forums. Or are there even more than 3?
i am so sorry ,i thought it two times failed to send.
thanks for your appreciated reply
martensiticz
That specification, as OSIRIS7 point out is no longer specified in contracts in Europe. But if you have a copy, keep it (I keep mine). Because most older buildings used it in Europe. It was the best in Europe.
And it is the major contributing document to the new EN10025. Steels described in DIN 17100 have same properties now listed in EN 10025. What has changed is the format mostly.
For newer works, use EN 10025.
