DIN908 Plug
Yes, if the port you install it in matches the plug and you use a sealing washer. The thread is British Standard Parallel Pipe.
Ted
I notice there are 2 type of sealing washers i.e aluminum and copper.
If my port material is aluminum, can i use aluminum washer too?
R.Efendy
I prefer a stainless steel washer with a bonded buna o-ring rather than a soft cu or al washer which must be crushed to seal.
Ted
thanks for your reply. Appreciate that.
R.Efendy
