bigheadted
the reference to an inveter drive at work is 0-10v, the reference under general opperating conditions doesnot exceed 2.5v to achive the required speed. The reference comes from a PLC analogue output. before my time there was an issue that when the plc was first switched on it set its output to -10v which the drive didnt like, so a diode was put in series with the reference to prevent the reverse voltages. my question is, how would the forward bisa volt drop of the diode affect the drive. surely it will drop the refernce voltage the drive sees by 0.6v, which is quite a large proportion of the running refernce level. am i correct? does the volt drop across a diode depend on the currentr flowing through it?
