Hi.. I have created an ABAQUS model with viscoelastic material to understand its creep or deformation characteristics. In which, the material is subjected to 10,000 cycles of repetitive loading (0.1s loading, 0.9s unloading: Total 1sec in 1 cycle) as attached herewith. To simulate this, I have used direct cyclic step, with loading cycle using tabular data as attached (for 1sec, 1cycle). But my doubt is I have 10,000 cycles (10,000 sec), so should I need to give the amplitude loading corresponding to 10,000 sec in tabular data?? That would be more cumbersome, so is there a way to give the amplitude loading for one cycle using tabular data but I wanted to say to the model to apply this amplitude loading repetitively for 10,000 times/10,000sec? Please note that, after each cycle the strains should be accumulated from each step. Any inputs in this regard will be appreciated.
