Costin Ruja
Is there a way to do this ?
I have 2 length parameters, a and b
IF a==1 THEN b=[1,2,3] discrete dropdown values
IF a==2 THEN b=[4,5,6] discrete dropdown values
I am trying to copy the behaviour in NX or CREO where you can have some part with a bunch of parameters and after you select all the correct values with dropdowns (considering that some are dependent on the previous parameters) you remain with only one "configuration".
Thanks!
Best regards,
Costin Ruja
Thanks!
Best regards,
Costin Ruja
