Dished End & Shell Weld Joint Detail
oguzzz
15
Is it possible to use Table A-2 (C32 to C35) weld joint details which weld internal dished head to internal shell surface for a column with ID 8000mm and thickness 35mm in accordance with EN 13445-3?
Could you clarify with technical details?
Regards.
  • Table A-2 EN 13445-3.pdf
