Cerkit
- Jan 18, 2016
- 99
Hi. Can someone explain why generators on distribution networks result in the increase of voltage on the network?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
When the generator is connected to the mains at low voltage at the last farm, the only way to push power into the mains is to raise the voltage at the farm end above that at the substation. So the original voltage drop pattern is reversed.
