DLs & DLr
MohdYaseen2010
101
Dears;
in reference to API 650, edition 13;
(1) DLS (shell dead load) defined as nominal (Shell + Any Framing (but not Roof Plates) supported by Shell & Roof) Weights; so I kept DLS as =
Nominal (Shell + (Roof Framing/Structure + C. Angle + W.G + Insulation + Ladder + Nozzles + Rafter/Purlins)) Weights.
My question; is it correct to include Rafter/Purlins weight to DLS as long as assumed its attached to the Roof?
(2) DLR (Roof Dead Load) defined as nominal Roof Plate + Any Attached Structural) Weights;
= Nominal (Roof + (Roof Framing/Structure + C. Angle or Top W.G + Roof Insulation + Roof Nozzles + Rafters/Purlins) Weights.
My question; is it correct to include C. Angle or Top W.G (as applied) as part of the attached roof structure where its shared component between roof/shell?
Mohd Yaseen
A: Yes... What is W.G.? ( Wind Girder or weight of soil above tank foundation footing ???)
A: NO!! C. Angle or Top W.G. shall be included to shell wt calculation.
The following definitions are copy and paste from the code..
DLS = total weight of the shell and any framing (but not roof plates) supported by the shell and roof ,
DLR is the nominal weight of roof plate plus any structural members attached to the roof plate, .
Dear HTURKAK;
Thanks for your prompt response.
W.G referred to Wind Girder.
Ok, you paste the definition from the code, however, my question for part A still mystery and not clear?
Mohd Yaseen
