Does anyone know how would one use “mutexes” in fortran user subroutine so that I can run abaqus job
Mousumi Ghosh
Petroleum
Apr 19, 2018
5
I really would like to run my abaqus jobs (that have user subroutines attached to them) very quickly. I have read some sections in documentation about calling a utility subroutine called "MutexInit". I didin't understand when i could use it so that there will be no errors!!!
Could anyone please direct me to anywhere where I can have an idea of what to type in my subroutine files so that I can use cpus 4 or higher to run my abaqus jobs super fast?
Please and thank you very much!!
You need to call it at the start if you want to use it but I doubt you need to. If you just want to utilize more cpus and you don't have your environment file set to this number then you can just type cpus=4 from the command line when you run your job.
Hello BJI:
Thanks for the reply.
If my subroutine contains code for writing output variables to a text file, will the abaqus job (with the subroutine) still run on parallel processors?
