It's an interesting question as it also means the MAWP of the vessel is in guage pressure, i.e. it is relative to the external pressure. so in space, 2.8 barg would be the same as 2.8 bara. At 17,500 ft - 0.5 bara atm pressure, 2.8 barg would be 3.3 bara
The issue is also how you correct for this on instruments, especially those that use a near perfect vacuum.
You need to zero all readings, guages or transmitters to the local atmospheric pressure. Same with the relief valves? So setting the pressure at sea level to 2.8 bar g would result in a higher pressure at 8000 ft unless you revised the set point locally.
At higher pressures the difference is essentially negligible, but at 2.8 barg, you're not out of the woods on that one.
Have I got that right?
