siberiankhatru
- Aug 27, 2019
- 6
Bolts are seldom under compressive load, but what if we had an situation, where a non-preloaded bolt was under varying compressive load (load ratio R>1, i.e the loading is fully compressive).
For example, the situation could be a column base connection without grout where the anchor bolts and nuts carry the compressive load from the column.
Details and FAT classes are presented in the design standards Eurocode 1993-1-9 and DNVGL RP C203 but the details are meant for bolts which are mainly or somewhat under tension. How much better FAT class would a non-preloaded bolt have if the load range was fully compressive?
