IdanPV
- Aug 26, 2019
- 445
Hi All,
A tube with outside diameter of 3/16" and 1mm wall thickness is winding around a 1000Watts heating element.
The fluid (water) enter to the tube in one side and exit after vaporization, as steam, from the other side.
Tube length is 200mm. No welding or brazing is involved in the construction.
Does this configuration need to be design, constructed and stamped in accordance with ASME BPVC (Section I or VIII)?
I have go through Section VIII-1 and the only thing I found is that according to Section VIII-1, U-1(c)(2), structures whos primary function is the transport of fluids are not included in the scope of the division.
I didn't find anything in Section I.
Please advise.
Please advise.
