We're creating a chamfer by pressing a form pin up against a relatively sharp corner in a bore. The chamfer forms between a face and a thru bore. So we used an arbor press. I measured the force at about 750 lbs. So now we are buying a pneumatic press. It has adjustable speed and force. Does it make a difference if I use a much higher speed (like a hammer hit) and a lower force , or a slow speed with a higher force? Since we are displacing material, does the speed at which I displace the material matter?
