Does WD-40 Rust Remover Soak cause hydrogen embrittlement on springsteel?
bencuri
HU
I would like to de-rust some of my spring steel tools with WD-40 Rust Remover Soak. In the technical data sheet of the normal WD-40 product, it is mentioned that:
"EFFECT ON MATERIALS
HIGH STRENGTH STEELS: (for hydrogen embrittlement)
Certified SAFE according to the Lawrence Hydrogen Effusion Test"
The problem is that in the WD-40 Rust Remover Soak technical data sheet I did not find any information like this.
Does anyone know if the Rust Remover Soak is also safe to use on high strength steels without causing hydrogen embrittlement on them?
