TroyD
- Jan 28, 2011
- 98
I'm looking for some input on this unique roof concept. A custom home builder proposes to construct a domed roof over the front porch, using "trusses" made of multiple layers of 3/4" plywood sheathing cut to achieve the desired shape. I am contemplating what it would take to show that it works and to satisfy the local building official. I have made a few comments in red. Obviously, multiple layers of plywood glued and nailed together would make a stiff member. The clear span is barely 8'-0", so if the contractor could get 12 ft long panels they would span the full distance. Could maybe even get by with 2 layers. I assume the roof sheathing will also be plywood, but I don't know how the contractor intends to attach the roof sheathing to the "trusses", or get the desired roof sheathing curvature. Some coordination is needed to address
I have the APA's plywood structural properties info that I can use to determine the composite member's E, I, Sx, etc. the check bending, shear, and deflection. I need to research fastener spacing requirements and adhesives for this application.
What other engineering concerns might I have overlooked? Project is SE Minnesota, ground snow load is 50 psf.
-Troy
-Troy
