mrengineer11
Petroleum
In different Oil & Gas companies I have worked, engineers tend to say that any pressure rating from 600# and above, double block and bleed valves are required. Is there any API or similar code or RP that recommends the use of DBB at or above a pressure rating?
Is double block and bleed valve required for chemical injection line i.e. upstream the main process line?
Is double block and bleed valve required for sample lines line i.e. upstream the the sample collection point?
What is the best way to select the most appropriate DBB for the application?
