Vitalis 1977
Hi guys,
Could somebody assist me on the following queries?
Double end studs with reduced shank according to DIN 2510 have been specified for the bolting connections of a vessel's nozzles.
Design temperature for this vessel is 450 deg.C and Pdesign = 25 barg.
1)Why use these types of studs instead of typical stud-bolts or even bolts? Is it because of the elevated temperature?
2)What is the purpose of the extended parts (marked in attachment) of the threaded ends.
3)How can I calculate bolt lengths for various flanged connections.
Thank you all in advance.
