JVT_Stress
I'm working for an EPC contrcator based in Europe and we design and construct piping according to PED and EN13480 code requirements.
Besides my job as a pipe stress engineer, and i'm also tasked with setting up the piping specifications for our projects.
When we request a quotation for piping components, we notice a trend that our typical material suppliers are offering more and more "double or triple certified material" EN/ASME/API?
Example:
When we request welded pipe according to:
EN10217-5 P235GH DN900 (32") 914mmx8mm.
we get offered a welded pipe according (double certified):
API5L grade B/P265GH TC1 acc EN10217-5 with dimensions 914mmx9,5mm?
So for the material part I have no issues, because if it's double certified it conforms to our request EN10217-5.
But on the dimensions I have serious doubts, because I think the tolerances between API5L and EN10217-5 are very different?
The same goes for fittings:
If we request fitting
EN10253-2 P235GH ELBOW 3D DN150 (6") wall thickness series 2 (WT=4,5mm) type A
we get ANSI B16.9 ASTM A/SA234 WPB & EN10253-2 P265GH certified with dimensions 6"xSTD?
Which to my opinion is not acceptable?
Does anyone on this forum has the same expierinace with material suppliers?
How do you deal with this double or triple EN/ASME/API certification?
Because if I insist that the material supplier must be conform to our material and piping specification the price and delivery time of these piping components goes up. With a frustrated PM as a consequense.
Best regards,
Example:
Best regards,
