Fernando Lopez
- Oct 7, 2024
- 2
Is the double-plate shear connection used as a connection? Do you think this is a a possible solution in practice? What about its design? All your answers will be appreciated. Thanks
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Thank you for the answer. I do not have a specific problem to solve. I was just wondering if the double shear plate is a good solution in any case. From the answers I am receiving I am confirming that this connection is not recommended.You are probably going to have tolerance problems accurately locating the double plate so that the beam web can slide between the double plates with a negligible gap between the plates. Likewise single plate shear connections require a weld on both sides of the plates. You can't get a weld on both sides of both plates. Accordingly one of the plates will require a CJP weld which will add significant cost. What kind of shear strength are you looking to develop that you think you would need a double plate? Why not just use A490 bolts, or larger diameter bolts, or a thicker plate, or 50ksi plate material. What is the governing limit state that's giving you a problem?
