Saedhalteh
Hello all,
I have question regarding Dowel bars and Development length that I hope you can help me with :
If the bearing capacity of the concrete is not sufficient to transfer loads from column to foundation then we need to put dowel bars.
My question is, does placing dowel bars means that we don't have to check development length for concrete reinforcement and that the column reinforcement should stop at the face of the foundation.?
or it is a must to check the development length in all cases ?
Additionally, Do we check the Compression development length and the Tension development length and then apply the larger ?
