DPV Files.
NXJockey
Automotive
Feb 9, 2009
104
Does any one know if its possible / how i could generate a DPV (drafting standard) from an existing part for NX6 or NX7.5.
we have 'inherited' a lot of external customers parts for a specific project, and need to be able to match the standard.
If i have to, i can interrogate every setting, but wondered if there was an easier way.
Cheers,
NXj
delete all the geometry in the file and use the part as a template file. part already has the settings you want so use it as a template.
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5, Beta NX8.0.0.15
Also, be sure your customer defaults are set to use the settings from the template file instead of your set standard. In NX6, that option is in 'Drafting -> General -> Drawing tab'.
