DraftSight Enterprise Plus 2020 constraint issues
DraftSightIssues
AT
I want to set a linear constraint, rename it and change the value. The drawing consists of just a straight line and has has no other constraints yet. When I try to change it I get the error "A dependent expression cannot be evaluated."
I then tried to add a new parameter and change the name of that, but I got the same error. I am very confused, and cannot find a solution. I am new to the program (used AutoCad before) so maybe I am overlooking something.
Every input is welcome, thank you in advance.
