Jan 12, 2022 #1 RomanKatz Industrial Aug 29, 2012 52 0 0 IL Hello Friends, I have a 4m3 vertical tank. At the bottom, 2'' draining valve. How to calculate the draining flow? It is obviously height dependent, so if it has a 1m3 water in it? Thanks. Best Regards Roman Katz
Jan 12, 2022 1 #2 LittleInch Petroleum Mar 27, 2013 21,097 2 38 GB Try this https://www.engineeringtoolbox.com/flow-liquid-water-tank-d_1753.html other similar exist - google flow rate from hole in tank Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Jan 12, 2022 1 #3 pierreick Chemical Nov 20, 2005 1,224 0 36 TH Hi, Consider this link to support your work. https://teslaandi.files.wordpress.com/2015/10/tank-draining-derivation.pdf Pierre Upvote 0 Downvote
Jan 15, 2022 1 #4 mk3223 Mechanical Feb 4, 2006 1,476 0 0 US Suggest to have a "Crane TP-410 Flow of Fluids" for the engineering reference. http://www.flowoffluids.com/media/1096/tp410previewsm.pdf Upvote 0 Downvote
