Drawing view name font size 5 and scale font size 3.5
Balaji R
Automotive
Jul 27, 2022
5
Is it possible to change font size for view name as 5 and scale as 3 5.
Both are in same text
I can able to change the font size fully.
Can any one please help me on this
within the text, select the subtext you want to change font.
if you change the font at the text level then all text is affected.
Eric N.
Can you please explain in detail. How can I select the text in sublevel?
I also attached image of the text size to be changed
I have written code like this.
Dim DSheet1 As DrawingSheet
Set DSheet1 = DrawingDocument1.Sheets.ActiveSheet
Dim DrawingView1 As DrawingView
Set DrawingView1 = DSheet1.Views.ActiveView
Dim DrawingText1 As DrawingText
Set DrawingText1 = DrawingView2.Texts.Item(1)
Call DrawingText1.SetFontSize(0, 0, 5)
 https://files.engineering.com/getfile.aspx?folder=7a022dd2-4687-4547-9c9f-7462e8d234c1&file=Screenshot_2022-07-27_194356.png
plz attache picture as image so we can see them without 5 clicks !
Eric N.
like this:
Eric N.
