Drawing view - unusual issue 1
TudorM
Automotive
Mar 30, 2020
100
AT
Hello ,
Today i had a very unusual issue at work and do not know how i will solve it tomorrow .
We moved to Catia R27 and today i started to do a drawing, the unusual behaviour is like this : i am bringing a front view of an assembly and after making a projection view bottom , left , right or top is not keeping the alignment links . Is acting like copy - pasted in the sheet and without links at all to the reference view . I admit i brought the settings from R26 to R27 before starting the drawing and was doing only 3d but i deleted them , restarted the computer ,i even took the settings from other coleague wich didn't had this issue and still the same behaviour. Opened the same drawing on other computer everything fine on mine how i said is acting with no position links at all :( (position independently of reference view missing ) and "according to reference view as well - acting like copy -pasted.
If anyone knows a solution or maybe there is an option i couldn't find please share , thank you .
Did you create a separate CATENV folder and separate CATSettings folder for each CATIA version when done the installation? If not, be aware that they share same folder and this can cause problems...is not the case with 3DX...
The migration of CATSettings from one version to another is well documented in the help files.
Fernando
Yes i made separate folder for 27 settings and changed the path as well from Env.Will double check tomorrow cause i done this couple months ago,maybe indeed something is wrong with that,thank you Ferdo.
Hi Ferdo , was indeed problem with instalation - and this caused the strange problem, all solved , thank you !
