  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
drawing
mikeo56
28
I am new to AutoCAD having just acquired AutoCAD LT. I am attempting to draw a diagram of molding 5 1/2" in height, however I cannot arrange the model screen to represent the diagram large enough where I can work with the drawing . On the screen the 5 1/2" is closer to 2", making the work almost impossible to see it is so small. How does one adjust this?
Second, how do I print the diagram to scale?
Thanks, Mike.
I do not use LT but it shall have the zoom toolbar's icon
Usually it is on the firts icon tool bar at the rigth hand, it is aicon with four arrow from center to N S E W
Other way type at the command line
Z and the E
Z if a nicname for ZOOM and E for EXTEND
Pardal
My first question is how big is the monitor screen? Secondly is the top and bottom of the ACAD viewing screen cluttered with Icons, multiple command lines and the typical desktop bottom menu?. Streamline your screen so as to have as much drawing area for a functional ACAD program.
You can also set your drawing limits to the approximate size of your drawing and perform anyone of the several zoom commands. I got a 14" compaq presario screen on which I perform architectural and mechanical drawings w/ ACAD 2004 with relative ease. You should be able to do the same.
I too would recommend trying Chicopee's route to increase the drawing area. For your desktop, set your taskbar to autohide. Not sure if Express Tools works with ACAD LT, but if it does, use the command "fullscreen"; it basically autohides your ACAD menus to increase your screen area. Also, make sure "display scrollbars in drawing window" is unchecked in your options, since you can pan and zoom with a scrolling mouse. Reduce the status bar to no more than 3 lines.
Flores
You can use Z and then E
or Z and then W for Zoom
and Window and you have
to select the first and
second point of the window.
To plot, use Z and E
and then scale 1:1.
There should also be a button
for zoom at the top of your
screen as another choice. Another
button should be pan to move
around in the drawing after you
have zoomed in to the area you want
to work on.
