AaronMcD
- Aug 20, 2010
- 273
I am designing a small 3 ft retaining wall that will retain a residential driveway. The owner plans to have heavy equipment driving over the driveway for future work. There is no geotech. The main failure concern is sliding force from equipment. Which sound better to you?
1) Design the wall to resist the forces via friction (0.3 assumed) and passive pressure (250 assumed, below top 8"). Keep the driveway separated from the wall.
2) Tie the driveway into the top of the wall to resist sliding.
The only concern I have with (2) is that I don't know the soil properties and I'm worried the driveway could settle or heave or crack under equipment, held in place at the edge. I would still need the wall to support itself and construction loads behind it. I was leaning towards (1). Typically I have a geotechnical engineer to tell me where he wants slabs tied to foundations and where he wants them to float.
