Drop Test
SalamiVice
10
I need to drop a 5 lbs steel ball onto a optical lens from 6 feet up.
Does Cosmos drop test even allow me to do this. can i fix the lens to be my surface and have the ball drop on it???
I am running SW 2009 with all the toys so any advice will be helpful.
Some years ago Vince Adams did a presentation at a SW regional meeting and compared what drop test could do with more sophisticated software.
1. Drop test is not particularly fast when compared to LS-Dyna.
2. It is a subset of Cosmos/M and uses the same methods.
I believe you can do this in Cosmos/M which you probably have if you have Drop Test.
TOP
CSWP, BSSE
"Node news is good news."
If you are running SolidWorks Simulation Premium you can run a non-linear dynamic study of an assembly with the steel ball in a no-penetration contact with the lens. You can then give the steel ball a velocity as an initial condition, initial condition is found under fixtures. Make sure that you orientate the target plane and gravity correctly.
