.DRW viewer
Tobias123
1
Hi
My company bougth Pro-E ½ year ago and we need to implement in the PDM-system. My company’s PDM system is complicated and our purchaser are at the time only able to se the *.DRW files, not the *.PRT.
So I need a viewer that can view *.drw without the *.prt!??? Is it possible??
I tried the Product view express but the viewer is bad and need an extra file generated *.pic. Our PDM can't handle the extra file without expensive change.
Can anybody help with a viewer??
I second that - eDrawings is the way to go.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
On some drawings, embedding the pic in the drawing caused the file size to be several megabytes. Without the embedded pic the drawings were under 500kb.
I like eDrawings because a complex plastic part file that is 5+ megs in Pro/E shrinks down to less than 200kb. When you install the Pro/E plugin, the process is painless, and (perhaps more importantly) you aren't giving away your Pro/E files.
