Duct Burner Design for HRSG
Sohail Sabir
1
Require your recommendation to install a duct burner on exhaust of Gas Turbine V94.2. HRSG is a horizontal type, forced circulation, superheated steam with dual pressure. Inlet duct of HRSG is 5.75 x 5.75 (m) of cross section (drawing attached). you are requested to please provide your technical expertise on
1. Location of Sigle duct burner for homogeneous temperature profile
2. Risk Analysis
3. Thermal Stress Analysis
 https://files.engineering.com/getfile.aspx?folder=54b6991e-fb4e-46fc-80a2-d4b43a4468b8&file=HRSG_Layout.pdf
That comes with a price. Any design you require must be certified by a licenced engineer.
Your post is asking the sorts of questions that drive the development for an engineering concept study specification. Contact the burner manufacturers in the HRSG burner business this link should give you a starting point. link You will likely need an expert to develop the plant integration.
The OEM for your HRSG is also a good place to start.
The usual disclaimers about the value of free help on an internet forum apply.
