Ductile Damage Converge Problem
Diogo Cabrita
Hey friends,
I am trying to apply ductile damage in a bending cyclic test on a pin. Using Static General Step.
I can run the simulation till the end without damage, but when I apply the ductile damage to the material, I get converge problems. It only runs until the elimination of the first elements and then gets aborted, with the usual message of “Too many attempts made for this increment”.
This is a simulation of an experimental test, I wish to simulate the full failure of the pin.
Looking at the job diagnosis, some contact occurrences: Overclosures, Maximum contact force error, Maximum penetration, points now slipping, points now sticking warnings show for Nodes around the eliminated elements, and warnings like zero pivots, and negative eigenvalues are shown.
I apply the ductile damage parameters, Fracture Strain, and Damage evolution in tabular form (D,displacement) that I simplified to just two lines (D=0 and D=1).
On the step module I am using NGeom: On and automatic stabilization, with dissipated energy fraction of 0.01.
I am using Reduced Integration linear elements C3D8R, with Stiffness Hourglass Control and max degradation of 0.998.
I think the problem is either with the damage parameter definition or the mesh definition.
Can somebody help me? I have read and tried of everything, but I can’t seem to get pass this problem. If you have a question regarding the model definition I will be glad to answer.
Thank you very much, Diogo Cabrita.
 https://files.engineering.com/getfile.aspx?folder=375a9438-c534-4189-b999-8f00fb2b1049&file=Pin.png
Try enabling automatic stabilization in the step settings.
