E7018 & E7018M
FAHADRANA
4
Dear Experts;
What is the difference between E7018 and E7018M as per ASME Sec II Part C.
M.FAHAD RANA
WELDING ENGINEER
The M is for the Metric / SI version of the spec.
M often denotes military grade. There are many differences in the two...including CVN test temp. Suggest you open the Code to see.
Agree 100% with David regards actually opening the code.
If you are a Welding Engineer you should not be asking these questions on an internet forum.
