Earthquake Load Patterns in ETABS
minx_kutor
9
I have an ETABS model for a building with 6 levels. The building has different eccentricity ratios for each floor hence I have defined 6 different Earthquake load patterns (each of them for one floor) in both directions. In the load case tab I combine them to form one load case in each direction. However, this idea works in Y direction, in X direction I dont see any forces or displacements. Please can someone help me out.
You don't need to have six different load cases. You have the ability to override diaphragm eccentricities for each level. The value of eccentricity is input as a value in feet, which is based on the actual eccentricity.
The floor plates I have is not a regular shape so to measure and input eccentricities will take a long time and its difficult to be accurate. Hence.
